Re: Price Pfister OX8 Shower/Tub Valve Installation
Posted by Marty on January 15, 19101 at 22:46:17:
In response to Re: Price Pfister OX8 Shower/Tub Valve Installation
Hi Chris.I'm very familiar with PP tub and shower rough-in valves. All PP valves come with a seperate plastic ring which is used when installing the valve onto an acrylic or fibreglas tub or tub and shower enclosure. This ring goes onto the inside of the inclosure, with the valve body on the backside of the enclosure. The shower wall is therefore sandwiched between the two black plastic rings and is now preset at the correct depth to install the trim package. It's great when installing them on tub and shower enclosures. You just need the correct holesaw (3.5" I think) to make the hole in the enclosurewall. If you're just installing the valve in a shower with ceramic tile, the seperate ring is not needed and can be discarded.Good luck, Marty
