| Posted by hj on January 15, 19101 at 08:06:01: | |
| In response to Re: Portable dishwasher | |
Once it reaches the dry cycle the water usage has ended, so you can turn off the water. Do not disconnect the drain however until you are sure that the dry cycle does not use the pump to eliminate any residual drained water. : We recently "inherited" an older, portable dishwasher. I would like to know if I can turn the water off once the cycle hits "dry". I don't think it is needed at that point, but hesitate to turn it off in case it somehow ruins the dishwasher! Please, someone with any knowledge - let me know!!
| There are none. |
