| Posted by hj on January 15, 19101 at 08:03:30: | |
| In response to Re: Drain Vents | |
You need vents for the sink and washer. It should run through the roof. If you use a mechanical vent you have to provide access to it and they can fail. : I am in the process building a utility room where I will be moving my washing machine to another location and adding a sink to a new location. The washing machine was drained and vented with the pipes exposed outside the wall. When I move them I would like to put the pipes in the wall. Do I need vents for the sink and the washing machine? Can I Leave the vent in the wall, or does it have to run through the roof. The sink and the washing machine will be the only drains on this line.
| There are none. |
