| Posted by frank veno on January 11, 19101 at 22:14:20: | |
| In response to Re: Basement Bath | |
: : I have a rough-in for a full bath in a U-shape-corner of my basement. I want to put in the walls and floor myself and have a plumber install the fixtures. The info I need is the location and thickness of the walls. : : Concrete wall measument - 11' wide (back wall) & as long as I need it. Picture the layout-Sink on right, toilet center, and shower on left along the 11" back wall. : : I have a 4" pipe out of the floor connecting to a 2" vent & a 2" drain. I assume this is for the sink. Located 8" from back wall and 30" from right side wall. A 2" pipe for the drain is 17" from floor. : : Centered is a 4" toilet fixture on floor 21" from back wall. Does this have to be raised for the floor? (2x4's with 3/4" plywood flooring.) : : 4" cap on floor is 14" from back wall & 44" from left side wall. Is this the tub/shower drain? I plan on putting in a long shower stall. : : Do I put the wall studs directly against the conrete walls or bring them out a bit for deeper wall thickness? Do I need 6" wall depth to hide pipes, etc? What is the minimum distances from the walls for the fixtures? : Is there any way you can lay the existing pipes out in a diagram and email it to me. (MWIN228070@aol.com) If a plumber roughed it in one of the pipes is most likely the toilet vent. Hard to picture the way you are describing it
| There are none. |
