Problem with new deeper sink
Posted by Miller on January 06, 19101 at 22:07:45:
I just installed a new sink that is 5 inches deeper than the original. I now have a problem, the drain out of the house is now higher than the outlet of my garbage disposal. Is this a problem or not. With the outlet drain being higher than the garbage disposal outlet will this cause the disposal to wear out prematurely, is this type setup in code, will the water inside the garbage disposal that does not drain completely cause an ordor problem etc... Since I am not a plumber I need some advise on this subject.
Replies to this post
