| Posted by No way on January 06, 19101 at 17:36:45: | |
| In response to no pipe is perfect | |
:The pipe itself has been known to :split as if someone cut it with a knife. Copper pipe DOES leak if you have aggressive water. If it freezes. If you have low pH. The pipe wasn't the problem unless there was high concentrations of chlorine. That's the same with copper. With high concentrations of chlorine in the water copper will leak over time.
| There are none. |
