| Posted by hj on January 05, 19101 at 21:59:12: | |
| In response to Re: moving Sump-pump/installing upflush toilet in basement | |
The one pump can be used to evacuate all the water used in the basement. But you will need an ejector basin which is larger than a sump basin. : Hi, : I noticed some very knowledgable responses on this bulletin board, regarding a similar subject to my current situation. Put simply I need to relocate a sump pump from the middle of my basement, to a more convenient location. I also want to install an upflush toilet. My question, can I install them in the same pit ? Can I use the same pump for double duty, or will they have to be seperate ? I understand if you do not know the answer to this, but any input would be appreciated. : Sincerely, : Karl Hirsch
| There are none. |
