| Posted by Louis Summers on January 05, 19101 at 16:27:58: | |
I want to add a fenced "cage" in the garage of my home, which is on a post tension slab. Will there be a problem using a ramset or other surface fastener to fix the bottom flange to the slab? If not ramset, is there another process that you recommend? |
