| Posted by John Scates on January 04, 19101 at 13:39:33: | |
| In response to Re: odour coming from drain | |
You probably have hair rotting in the drain, just out of sight. You need to remove the cover over the drain and pull the hair glob out. A coathanger wire might be needed to reach around the corner and get it all. I say this, assuming that you are not getting sewer gas back through a dry trap. If you have run water through the drain in the last week, it probably is not dry, so this would not be the problem. - John |
| There are none. |
