| Posted by ed on January 03, 19101 at 11:52:57: | |
| In response to Re: Bryant 340mav furnace | |
: Hi. I have a BRYANT model 340MAV high efficiency furnace that is 4 years old. : Last year, the furnace would stop running due to a pressure switch fault. I have : verified that the air flow is indeed ok. The problem seems to be the pressure : switch itself - the switch or contact within the unit is intermittent. If I jiggle the : wires and/or contact on the switch, the contacts close and the furnace will start : back up. : Obviously I need to replace the switch. However, i've been unable to find a source : Respectfully,
| There are none. |
