| Posted by Barry Dallum on January 02, 19101 at 12:42:55: | |
| In response to Re: cracked fiberglas shower | |
: Our 1 pc. fiberglass shower has a crack in the floor. Any suggestions how to fix it without replacing entire shower unit?
Fiberglass showers typically have an unsaturated polyester colored gel coat (the surface you see), backed by a low glass fiber content, high calcium sulfate or alumina trihydrate content filled unsaturated polyester. Procedure is: This method should work fine if the crack was caused by impact. If the crack was caused by weight loading & flexing, then it will likely crack again, if not there, then very close to it.
| There are none. |
