| Posted by Mark Winslow on January 02, 19101 at 03:57:55: | |
| In response to Re: Sewer Line | |
The line should not hold any water. When the line is run it should slope 1/4" per foot or 1/4 bubble on a level. Make the run as uniform as possible without any sags. Use sweep fittings whenever you have to offset the run. : I had a problem last spring with a plugged sewer line "City" about 10 feet from the house. When I broke : (litterly) the clean out plug I had to catch a lot of sewage. I used am auger to clean it out and found a big : clump of roots. My question is should that section of sewer pipe remain full of water or is there an improper : connection outside the house where the old septic system was removed. I have been toying with the idea : of replacing this section from inside the house to the main pipe from the city with plastic, so if it is presently : done wrong I need to make sure that I do it right. Thanks
| There are none. |
