| Posted by hj on December 31, 19100 at 22:54:40: | |
| In response to Re: Boilers | |
It would appear that the water is not circulating out of the boiler so the high limit will shut it down very quickly. The pump may have failed or the baseboard system may have an air bubble that is preventing circulation. : When thermostat is calling for heat, the system comes on for a brief period, then shuts down. It appears it's not making the full cycle for the temp range called for. Is there a set of points that might need replacing, or is it just a clogged system? This is for baseboard heat.
| There are none. |
