| Posted by Doug on December 28, 19100 at 19:10:41: | |
| In response to Re: Unable to remove faucet and drain | |
I recently faced a similar problem. I ended up using a hammer and chisel to remove the corroded nuts. : I an trying to remove an old faucet and I have most of the parts disconnected and remove except for the faucet and the drain. Both have nuts that are frozen with lots of mineral deposits around them (which I have removed as much as I could). I have tried a basin wrench but the nuts will not budge at all. The drain is in a similiar situation. : Any advice on how I might remove the items? : Thanks.
| There are none. |
