| Posted by hj on December 28, 19100 at 08:55:35: | |
| In response to Re: Boiler | |
The safe pressure for a boiler, assuming it is a hot water system, is whatever it takes to lift the water to the highest radiator plus about 5 pounds as a fudge factor. It should never go over 30 psi unless the boiler is rated at a higher pressure. If the system needs 25#, for example, and the pressure drops to 10 or 15, then the radiators on the highest elevations will not heat. : Got a quick question. What's a safe pressure for a boiler,and what is the affect if the pressure is too low,say 10 or 15 lbs,instead of 25 -30. Curious.
