Re: Electrical heat tape on water pipe in crawl space
Posted by Susan (error in first message) on December 27, 19100 at 12:03:24:
In response to Re: Electrical heat tape on water pipe in crawl space
: If your heat tape is 18 years old--remove it and remove it now! See the article at http://www.safetydeck.com/nltr/safety18.htm to learn more about the safety hazards of old heat tape.
: Furthermore, you shouldn't cover heat tape with insulation--if you feel you must, make it fiberglass or some other fire resisitant insulation.
: : Any pros or cons on use of heat tape under crawl space? We had one put on which is thermostatically controlled, approximately 18 years ago. A friend told me he had his removed because of fire potential...tape gets old, cracks, gets damp, etc. I think mine has some insulations over the tape too. Does anyone have a comment on the safety of this? (PS - an electrician went under the crawl space last year at my request but said he couldn't tell the condition of the tape since it was covered with insulation.)
Replies to this post
There are none.
