Re: Toliet will not drain waste only slowly the water
Posted by hj on December 27, 19100 at 09:47:15:
In response to Re: Toliet will not drain waste only slowly the water
Maybe you need a different plumber. Most plumbers can tell if the problem is a plugged main and if so how to cure it. And if it is not a clogged main they should also know how to fix the real problem.
: My toliet is acting as if there is a clog, but I have already had a plumer come out and snake the toliet. The plumer said it was either the spetic tank or the sewer from the street is clog. I don't think the house has a spetic tank and the county has been out and checked the sewer line and said it was clear. Could there be anything else wrong with the toliet before we dig up the yard.
Replies to this post
There are none.
