Re: corner toilets
Posted by hj on December 27, 19100 at 09:39:16:
In response to Re: corner toilets
The opening in the floor should be 12" from the back and also from the side wall to make it look right. It would have to be a very bad installation for the flange to be that close to the side wall. If your drain flange has a metal ring, it should rotate to the new orientation, otherwise you will have to remove the flange and install a new one.
: i want to install a corner toilet in the same location as the existing toilet....(lousy layout in bathroom)...
: it should fit right into the corner on the existing i need to redo the drain flange?..if so how?...
: (slab foundation) any ideas? ....thanks
Replies to this post
There are none.
