| Posted by Mike D on December 26, 19100 at 16:30:23: | |
This summer I moved into 4 year old house built w/ septic tank. Septic tank smell arrived in the autumn. Autumn. Hmm. Must be when the themostatic attic fan stops kicking in. I go to the attic. The smell is worst there. Found a vent pipe coming into the attic. Called county inspections. They said the builder must have forgot to put on the studor vent. Smell went away for a day. No smell in attic. But smell came back. It's not as bad in the attic, but I can still smell it up there a little -- about as bad as rest of house. Could find no other open vent pipes in attic. 2 4" vent pipes go thru roof, so don't need studor vents. Lots of studor vents thru rest of house. Under sinks everywhere. Had septic tank pumped. Problem went away for a few days. Fed bacteria to septic tanks. Problem not affected. Had plumber come and look for problem. He couldn't find anything. Have sniffed a lot of drains. Cannot find the source of the smell. Questions: 1) Any thing such as a smoke bomb I could flush down a toilet, to see what vents and whether I have any leaks in my vent pipes? 2) Any other way to find leaks? 3) Should I be able to find a vent pipe near the septic tank? Does methane etc. produced by septic tank go out thru roof, or is there a separate vent pipe for septic tanks that keep the tank from pushing bubbles through your toilet traps, etc. 4) Suggestions? 5) Any recommendations for a plumber here in North Atlanta that is an expert in these kinds of problems? (I've paid a plumber and a septic tank person. Never really wanted to be an expert myself...)
