Re: outside faucet leaks in wall when turned open
Posted by CASMAN on December 26, 19100 at 15:26:01:
In response to Re: outside faucet leaks in wall when turned open
You apparently have a freeze proof faucet which essentially means when you turn off the faucet it closes off the water flow approximately 8 or 9 inches inside the house, that is why when you turn it off the leak in the wall stops...its becuase the shut off point, is 9 inches in, whereas your leak is probably in the middle, it more than likely froze and created a leak somewhere between the outside and inside of the wall ie the middle, urgent No, fix later yes
Replies to this post
There are none. |
