Re: Leaking supply line to toilet.
Posted by John Bridge on December 24, 19100 at 15:35:03:
In response to Re: Leaking supply line to toilet.
Try snugging up the nut holding the ball cock/flush valve . . . just above the upper supply connection.
: I need help ....
: I installed a new toilet and am hooking up the supply line. Checked to make sure both connections were tight
: and turned on the valve. But supply line slow leaked from the top on the supply line fitting. I then used teflon
: tape on the plastic connection. Handed tightened and then wrench tightened. Again it leaked. I tried several
: different supply lines with the same results. Is there some goop or something to use? This is on a Toto Drake Toilet.
: Thanks ....
Replies to this post
