Leaking supply line to toilet.
Posted by Scott C on December 24, 19100 at 14:52:40:
I need help .... I installed a new toilet and am hooking up the supply line. Checked to make sure both connections were tight and turned on the valve. But supply line slow leaked from the top on the supply line fitting. I then used teflon tape on the plastic connection. Handed tightened and then wrench tightened. Again it leaked. I tried several different supply lines with the same results. Is there some goop or something to use? This is on a Toto Drake Toilet. Thanks ....
