| Posted by Bud..Suncoast Plumbing on December 23, 19100 at 11:55:24: | |
| In response to Re: gas water heater (hot water side corrosion) | |
Wiley: This is a common problem on hot water recirculation systems if the pump is causing excessive velocity of flow within the piping. Water softeners can sometimes be at falt. The water as it emerges from the resin bed of the softener can be pretty aggressive..it can excelerate decomposition of the anode in the water heater, this will result in early failure of the heater; and then it will start work on the hot water piping. Merry Christmas...Bud
| There are none. |
