| Posted by Mark Winslow on December 22, 19100 at 03:23:25: | |
| In response to Re: Kitchen Faucet Repair | |
: Help! Repaired my leaking one-handle kitchen faucet (Peerless) by replacing o rings, etc. Put it all back together, turned it on about half way, then turned the water back on under the sink. Faucet does not leak any more and I have great water pressure; however, when I put the handle in the "off" position, water continues to come out the spout. The pressure is less but it is a steady stream. I have taken the faucet apart 3-4 times to make sure all is correct and it is, I followed the repair kit instructions to the "t". Why won't my water turn off? I'm sure this must be something so simple,,,I just can't see it. Thanks! Did you replace the seats and springs? Sounds like one (or both) of the rubber seats isn't seated properly. Make sure the springs are installed properly.
| There are none. |
