Re: Electric Hot Water Problems
Posted by damacleod on December 20, 19100 at 22:25:36:
In response to Re: Electric Hot Water Problems
I did have a chance to check the thermostats and they were just above 120, I turned them down even further and the problem still persisted. The water gets really hot and I have to turn off the water and the breaker so I do not have all the hot water flow out the Relief Valve. Still in need of some helpful information. : I have an electric hot water heater, and I have a problem. : It seems that it heats up the water and then blows it off the relief valve once it gets hot. : Is this a problem with the relief valve or is it my thermostat or element? : I checked the temperature of the thermostats and they are not turned up very high, well at least It did not seem so. : How do I check my thermostats and elements to see if they are working properly? : I am comfortable trying this myself, any helpful hints/tips would be greatly appreciated. : Thanks
