Re: Hot Water problems
Posted by Madam Akmedia...Psychic Readings on December 20, 19100 at 07:26:06:
In response to Re: Hot Water problems
David:I see in my crystal ball a malfunction of
the lower element of your water heater. Although
it could be the lower thermostat, my first inclination is that if you replace that lower element, all will be well in your house and home.
"May the Blue Bird of Happiness build a nest on your head"...Madam "A"
Recently, our hot water has been running out much quicker than it ever did. At first I turned up the temperature which did increase the temperature of the water but didn't result in more quantity. Why is my heater producing so little water now, and what can be done about it. Thanks
Replies to this post
There are none.
