| Posted by hj on December 17, 19100 at 23:31:40: | |
| In response to Re: Can a pressure tank be suspended inside a well? | |
I suppose it would be safe until the suspension method rusted or rotted out, and then the tank would wind up at the bottom of the well. : I have an old shallow bored well that is used as a secondary well to provide water for garden irrigation. I need to relocate the pressure tank. Can the tank be suspended inside the well casing? The diameter of the well casing is wide enough to fit the tank inside if this is safe.
| There are none. |
