| Posted by hj on December 16, 19100 at 14:26:55: | |
| In response to Re: excessive moisture around tank | |
If you are referring to the water heater tank, and not the toilet tank, then there is no condensation and you do have a leak in the tank. But it is not repairable and the tank needs to be replaced. : the bottam of my tank has excessive moisture around it and it seems to be finding its way onto the floor under the tank. There is no leaks in the tank and I'm convinced the moisture is due to condensation. Any suggestions on how to prevent this from occuring??? : Thanks
| There are none. |
