| Posted by hj on December 16, 19100 at 14:24:48: | |
| In response to Re: Hot water | |
It must connect to the bottom it is a convection system without a pump. If it has a pump, then it can connect either to the bottom or the cold water inlet to the water heater. The check valve is essential, otherwise cool/cold water will travel through it to the faucets, instead of the hot water in the regular piping. And if it is a convection system, then the piping arrangement is very critical. The pipes must always flow downhill to the tank. If there is a drop and then a rise to make a connection, the return system will stop operating. : I just installed a hot water heater (gas). There was a line (1/2")coming off the bottom of the tank with a check valve, it appeared to be a return line. Does the line have to come off the bottom? And was that only a check valve, since I hooked the line up without a check valve and our hot water takes forever. Thanks
| There are none. |
