 : Two part question here: : 1) Do you know what is the shortest toilet available? : We have a very small powder room and as far as I can tell, : the current toilet is about 26" from front to back. It is : an old house (but not old toilet) with about a 13" or 14" : rough in so we lose an inch there. I saw a couple of one- : piece toilets that are about 25.5" deep, but of course : everything is 12" rough in. I'm trying to avoid re- : plumbing for the rough in. : 2) The other bathroom in the house has tiling all around : up to about shoulder height. This includes around the : shower/tub area. It's a painted plaster wall above that : point, which we try to keep as dry as possible. I don't : want to take out the existing tiling (it's in good shape : and period) and I would like to make the area above the : tiling in the shower/bath area more water proof. Is there : a coating that can be used under paint to water-proof : it? Also, it's Lathe and Plaster (not wallboard) so : I'm kinda concerned about this area.Thanks for your help. Mike K Mike, A good compact toilet would be the Toto either in an round bowl Ultimate or a Ultramax. These are 26.5 inches long with a 12" rough. This would put you out 28" from wall with a thirteen inch rough, and 29" with a 14" rough. Other options if you have at least 14" rough are the Carlyle elongated bowl with the 14" unifit adapter. That would put you out 28" from the wall. Terry
