| Posted by hj on December 08, 19100 at 08:46:39: | |
| In response to Re: Dishwasher Airgap has stopped working | |
When the airgap stops working, then water comes out onto the countertop. Your description implies that the dishwasher has stopped working. If so, then that is a more serious problem. The dishwasher should drain to the airgap and then the airgap drains to the disposer. That being the case, why do you say that the dishwasher drains to the disposer okay? : My dishwasher which drains through an airgap into the garbage disposer has suddenly stopped working. Dishwasher seems to be draining fine into the garbage disposer. The draingae from the airgap has stopped. Is it a matter of simply replacing an airgap gone bad or sdoes it indicate any other serious problem. Any help will be greatly appreciated.
