HOW DO I PLUMB A DRAIN FOR A WASHING MACHINE AND UTILITY TUB IN A BASEMENT
Posted by KENT on December 07, 19100 at 09:16:38:
I AM LOKING FOR INFO ON HOW TO HOOK UP A DRAIN FOR WASHING MACHINE & UTILTY TUB IN A BASEMENT. THE 2 INCH DRAIN PIPE IS 7'0" OVERHEAD THAT THE WASHER WAS HOOKED TO ON THE MAIN FLOOR OF THE HOME. I HAVE A SEPTIC TANK AND LEACH FIELD LOCATED IN THE YARD THAT ALL THE WASTE RUNS TO. ANOHTER OPTION THAT I MIGHT HAVE IS THE 4INCH TILE LOCATED UNDER THE BASEMENT FLOOR THAT RUNS TO THE SUMP PUMP CROCK. IS PUTTING A STACK PIPE IN THE FLOOR A VIABLE OPTION? THE CONCRETE FLOOR WAS TILED AND PUT OVER 6 INCHES OF CRUSHED STONE THAT WOULD PROBABLY DRIAN REALLY WELL.
