| Posted by hj on December 06, 19100 at 20:49:58: | |
| In response to Re: Water Hammer Arrester | |
There are none that will work for what you need. You are not getting water hammer, you are getting a check valve closing noise. If you get a ejector pump check valve, it will work better, since it has a rubber flap rather than the brass gate. : Iam looking to install a water hammer arresters to my sump pump line (2.5" line), what size arrester shoud I use?
| There are none. |
