| Posted by More worry about the crack on December 06, 19100 at 19:31:52: | |
| In response to Re: surface crack in fiberglass tub | |
Worry about the crack! Call the builder and have them fix it, don't do it yourself. The crack will worsen, leak water under the tub, and damage the woodwork and draw vermin, bugs and other such nastee stuff taht you'll believe the 90 dollars is cheap. : We have a newly built (2 yrs) home and I noticed while cleaning the 'garden tub' that there is a pretty large surface crack in the bottom. I called the builder and they said that it's commom (so I'm assuming that the tub is low quality) and they would : Thanks!
| There are none. |
