| Posted by hj on December 06, 19100 at 08:26:15: | |
| In response to Re: Natural Gas and Copper supply pipe | |
If you have the supply pipe near the heater, then use a new approved valve and a stainless steel connector. But before you do anything turn off the supply valves to each appliance and then see if you still have a loss. The utility should have done that and then said either that the system was secure with no loss, or shut you down because of a leak. If you have a loss/leak, get it fixed before you do not have a house to put the new heater into. : I own a 50 year old slab foundation house with copper gas supply pipe. I've removed the old wall heater and want to replace it with a williams or a Cozy. Is copper a safe pipe for gas supply? - there seems to be a lot of confusion, as I've gotten very different responses from people. PG and E came out today and said there was good pressure at the wall heater nipple and basicailly gave the thumbs up. said there was a loss of 3/4 of a cubic foot in 2 minutes, INCLUDING the water heater pilot light and this was also prob. ok. Thanks, Peter
| There are none. |
