| Posted by hj on December 05, 19100 at 23:34:30: | |
| In response to Re: Plumbing repairs behind walls & slabs | |
Under the slab you cannot use any joints. Inside the walls you can use anything you feel confident enclosing. : What is the code for repairs on plumbing water lines behind walls or below slab. I understand you can't use mechanical couplings.Where in the code book would find this info? : Thanks, Mikey
| There are none. |
