| Posted by hj on December 05, 19100 at 23:31:33: | |
| In response to Re: Garbage Disposal Hums | |
If it is an ISE or one if its relatives, there is an opening for a 1/4" allen wrench in the middle of the bottom, which you can use to move it back and forth until it unjams. Otherwise you need two broomsticks inside the disposer to rotate the cutters. : My garbage disposal hums but doesn't spin. I would like to learn to fix it myself. Is this something I should be able to do at home? : Thanks, Amy
| There are none. |
