cannot keep water in tub
Posted by Liane Goodrich on December 03, 19100 at 15:40:25:
No matter how much we tinker with the length of the rod that holds the bucket in the drain it leaks. It worked fine for several years, then starting leaking slowly. Now it leaks so bad you cannot tell if the lever is up or down without looking. Any suggestions???
Replies to this post
There are none.
