| Posted by Rick on December 01, 19100 at 11:43:20: | |
I'm replacing cast iron pipe with abs pipe in the bathroom. to join the pipes together I'll be useing fernco couplings. the main pipe is 3",about 3 feet under tile cement'and dirt.is the p1056-33,3"x3" the wright coupling for this joint.its a thicker rubber with no metal around it like some other ones I've seen. I have to use 3 other couplings,2 under sink.these 2 will connect the 2" drain pipes leading to the main.I have the same coupling for these 2 joints but only 2"x2". Can these plus the one I'm useing for the toilet be half covered in cement? or should I keep them out of the cement? are these the wright couplings to use for in cement and under ground? Thank you Rick |
