water heater
Posted by Masaaki on November 29, 19100 at 17:33:52:
I have a relatively new water heater that recently started to over flow through, I think the hot water drainage pipe that goes from top of the heater along the side to the bottom.
I always had the temperature setting on "hot" all the time and one day it was over flowing at a rapid rate. the only way I found to stop it was to turn the temperature knob to low or medium.
What is causing this and the solution? I want hot water all the time.
Thanks
Replies to this post
There are none.
