| Posted by hj on November 28, 19100 at 00:16:01: | |
| In response to Re: Black pipe coupling on a galvanized water line? | |
If you do not replace the black fitting, it will cause rusty water when it sets for a while. : I ran an outside galvanized water line, and at one point needed a bell reducer coupler, and all i could get was a "black pipe" fitting. Later I found out that black pipe is intended for gas lines. Will the black pipe rust, and if so how long can I keep it on before I need to redo the fitting?? : Also is galvanized compatable with brass fittings (eg shut off valve)? Thanks
| There are none. |
