| Posted by Matt on November 20, 19100 at 16:20:39: | |
| In response to Re: septic problem | |
I own a home built in 1927 with a septic (septic updated this year) I had problems with washing machines as well. I ended up having to install an Injector to to the slop sink where the washer bails out to. "Injector" might not be the right term but it is a stand alone unit that hooks to the drain of the sink and has an electric pump in it. When the water level gets to high in the pumps casing it JETS the water out and down to the septic. I needed this because my plumbing over the many years this house has been around has become lower than where the septic is where my washer is. Hope this helps. : : I have moved to a new house , for 2 days every drain worked fine. We just hooked up washer and did the first load of laundry and all this yuck is now standing in my 2 tubs and toilets and sinks. Help its sunday and i have tons of laundry to do. : Kim, : If however, it is an older home, it may just be a blocked main line. Terry
| There are none. |
