| Posted by hj on November 18, 19100 at 08:52:12: | |
| In response to Re: air hammer | |
More than likely the inexpensive valve the manufacturers use in the toilet has gone bad and is creating a chatter when it open or when it closes. Air is not the problem unless you pump air into the system or the water is shut off and drained periodically. : Our house is 2 years old. Sometimes, at night, when the toilet is flushed, there is tremendous air hammer sound and the entire bathroom sounds like it is going to come apart. There are 2 sinks, a shower with a temperature balancing valve, a low flow toilet, a tub. Looking outside, I see 1 vent on the roof above where the sinks are. : 1. Could the plumbers have left something out and could that be why I seem to have air hammer?
| There are none. |
