| Posted by James on November 13, 19100 at 14:07:59: | |
I just bought a house that was built in 1981. After I moved in, I found out that one shower has really low hot water pressure, yet quite strong cold water pressure. If hot water is used anywhere else in the house while you're in the shower, you get "shocked". Is this the same problem as I saw in other posts? Do I need a pressure-balanced faucet? |
| There are none. |
