| Posted by Rob Magill on November 13, 19100 at 13:28:29: | |
| In response to Re: Running out of hot water! | |
: The factory temperature setting is very low and few plumbers take the time to reset it so that could be your problem. Otherwise the factory's inexpensive elements could have burned out. Neither one requires replacing the heater. : : My home is 32 yrs old and I have a water heater that was installed 2 yrs ago. I cannot take a shower without the hot water running out. Do I need to replace my pipes? or buy a larger water heater? or can I increase the amount of hot water from my existing unit? Thank you.
| There are none. |
