I have a shower/tub combo with a "pop=up" drain. It has a spring loaded cazp assembly with a rubber gasket that seals to fill the tub. The cap unscrews, and you can take it and the gasket off, and what you have is a threaded plastic sleeve with what looks like a brass standard screwhead in the middle. I can't turn that screw head, if tha's what it is. The drain has become slow, and I want to be able to clean it out, but I can't seem to get the assembly out? Does anybody know how to dsiassemble this for cleaning?
