| Posted by Terry Love on November 10, 19100 at 10:08:03: | |
| In response to Re: Leaking trap at drain stubout | |
![]() : I installed a new kitchen sink trap which resolved a leak caused by a gaping hole in the trap bend, however I was totally unable to remove the slip nut from the drain stubout. I was able to pull the old trap arm pipe out because it wasn't flanged and I was able to slide the new trap arm into the stubout, but it leaks. I suspect the proper solution is to replace the old slip nut with a new slip nut and washer, however I think the odds of getting that slip nut off without destroying the stubout are slim. Suggestions? These are brass pipes and fittings. David, |
| There are none. |
