| Posted by Gary on November 09, 19100 at 17:48:11: | |
| In response to Re: CAST IRON PIPE | |
: WHAT IS THE BEXT WAY TO MAKE A HOLE IN A CAST IRON VENT PIPE IN ORDER TO RUN ANOTHER DRAIN INTO THE VENT? A hole saw should do the trick, although I suggest cutting a section out of the pipe and splicing in a "T" fitting. May take 2 bi-metal holesaws bits.
| There are none. |
