Purchased Am Std Cadet tank 4112.016 and elong cadet bowl 3459.016. Tank does not seat flush (no pun intended) to the bowl, and the tank rocks when seemingly bolt as tight as possible. The tank gasket that fits into bowl is sealed when the bolts are tightened, however, that the seal does not sit deep down inside the bowl, consequently, keeping the tank from sitting flush to the bowl. Is this normal? I've checked all of my other toilets, and the tanks are very secure. What am I doing wrong. By the way, the bowl to tank model numbers are a recommended match according to Am. Std. Thanks and Regards, Mike
