Wilkins Pressure Reducing Valve
Posted by Ken Crane on November 06, 19100 at 11:30:14:
House is 23 years old. I have a Wilkins Pressure Reducing Valve installed approx one foot above the water meter. It has a tag stating Range 25-75, Max Inlet 300. The valve has started to seep very slowly from what appears to be a weep hole. Is it possible to just replace the valve body (internal works)without breaking the lines or must I replace the entire unit? What must be done to check the pressure after the valve is repaired one way or another? In my area, I don't think high pressure is a problem. Thank you.
